Hello I am getting ready to put a bunch of vcds onto dvd and I have been using Ulead dvd movie factory 4.0 and I am able to get them all converted but its with mpeg audio and I have the ac3 plugin with it and I don't know how to make all the mpeg1 videos into dvd with ac3 audio for better compatibility instead of mpeg audio. Is there a way to do this with ulead movie factory or do I need to do something else such as freeware to make dvd's with ac3 audio. I am not wanting to rencode the video cause of it being already mpeg1. Thanks for any help. I have looked through the guieds but can not find exactly what I am looking for on how to do this.
Just author the VCD mpgs as they are. I think the mp2 incompatibilty issue is pretty small.
/Mats -
Tiny. Almost non-existant.
Hey cool guys thanks for the help it will save me a lot of time and I can just keep making them as I have been doing. cheers
Eric -
I use TDA for (the occational) "VCD as DVD" authoring. Takes care of the upsampling transparently,m and leaves the video alone, just as it should!
/Mats -
If you really, really want/need AC3 audio, you can just load the VCD mpg in ffmpeggui and convert to AC3. Then use the mpg as video source, AC3 as audio source when authoring. I've learned/come to realize that ffmpeggui accepts just about any file type, as long as there's some kind of audio in it.
/Mats
Research info needed
By vbthedog in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2011, 21:45 -
Some info needed on RipIt4Me
By Alloneword in forum DVD RippingReplies: 13Last Post: 29th Jun 2008, 11:48 -
Info needed on FA300P TBC
By Duchess in forum ComputerReplies: 0Last Post: 17th Jun 2008, 05:28 -
info needed on a CCD-SP7
By celchlepp in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2008, 17:00 -
karaoke info needed
By pabcsn in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 06:37
