XP runs CHKDSK on one of my data drives each time the system boots. Its fairly quick and verifies files, indices and security descriptors. Each time, it indicates the disk is OK. No showstopper but kind of annoying. Anyway to eliminate this short of re-formatting the drive and re-copying the data back onto the drive? Thanks in advance.
wwaag
Results 1 to 11 of 11
Are you running Norton Antivirus? I had a similar sitaution and when I switched programs, this solved the problem.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Turn it off.
I don't use Norton. Out of 8 logical partitions, this is the only 1. I recently recovered from a corrupted partition table on that drive, so I suspect that has something to do with it.
How big are the partitions and what filing system are you using?
The one with the problem (one of my removable backup drives) has only a single partition on the drive. I'm using NTFS.
If I were you, I would backup the data, delete the partition and then recreate and format. Then restore the data.Originally Posted by wwaagBelieving yourself to be secure only takes one cracker to dispel your belief.
Have you done a surface scan (as opposed to just the quick scandisk)?
Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
you can't....Originally Posted by lordsmurf
this happened to me recently. I deleted some files on the drive that I thought are corrupted and now it's fine.
I upgraded the drive, I did a hdd to hdd image copy, and since then that happened, so I don't know for sure if it's the drive copy or just bad files the problem.
if possible try to locate bad files, that could be the problem, just some corupted files on the drive. -
Odd question - have ou been shutting down properly and fully?
BTW, you should be able to eliminate chkdsk with MSCONFIG. -
Problem solved--I think. Deleted the partition, created a new one, and re-copied all of the files. Re-booted and no CHKDSK. Again, thanks for all of the replies.
wwaag
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
Hard disk report (Windows CHKDSK)... conclusion?
By PartingShot in forum ComputerReplies: 7Last Post: 12th Mar 2010, 13:48 -
CRC Error on Data File, CHKDSK Fails to Repair, Now What?
By PartingShot in forum ComputerReplies: 6Last Post: 16th Dec 2009, 16:56 -
XP chkdsk stops at 56% on stage 4 of 5...
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Jul 2009, 00:11 -
Nonsensical error message from CHKDSK...
By ntscuser in forum ComputerReplies: 8Last Post: 9th Nov 2008, 08:51
