  1. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Try Vegas it has some neat filters....
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  2. this programm, takes too much space.. is there anything can be done with VDub? i tryed but wasn't satisfyed with results, is there any special filters i could use?
  3. It looks like a poor light record. I think it's hard to fix.
    Good luck.
  4. it is a poor vhs rip...
    Feb 2004
    Australia
    And yes ? ... fix what ???
    In vdub , video filter's , apply resize , increase height by 10 .
    Back in filter add area , cropping is now available , crop 10 from bottom to remove that lower crap .
    (you may only need to increase by 6 and crop by 6 , depend's on existing condition within curren source)
    As for the static noise ... try conbination of smooth / blur filter's to adjust .
    Never had issue with static noise in picture before ... up to you to try .
    When ready , save as avi (set video and audio compression first) or
    Frameserve to bbmpeg for encoding to mpeg2 for later dvd project .
    Static noise from capture's : capture video by video capture unit ... audio only via line in (mixed input can lead to this problem) .
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    avisynth + convolution3d
    https://forum.videohelp.com/viewtopic.php?t=225951
    Then either clean up in avisynth or vdub before frameserving to an encoder.
    Read my blog here.
  7. Try AviSynth and the ChromaShift filter. Also try the temporal cleaner.
    Darryl
