Toturial of converting different kind of video to both iPod and cellphone supported format(mp4, 3gp, mp3)
1. Download Moyea 3GP PSP iPod Video Converter by the following link http://www.nunufashion.com/software/trialVersion/ipodvideo_setup.exe, install and run it.
2. Choose the output file format that you want to convert by clicking the file three button. (mp4, 3gp, mp3)
3. Click the "+ icon" to open the video files that you want to convert.
4. Select the video file that you want to convert, and click setting button to set the start position and end position of the video. Also you can adjust the contrast and brightness of the video, while you preview it.
5. Click the browse button to set the path that you want to the output files locate.
6. Click the drop down list to choose the default profile for you cellphone / iPod video. And you also can create/edit new video profile according to the media specification which your device(cellphone, ipod, psp) supported.
7. Click go button to run the converting. The process bar will show the percent of the converting operation. After the convertion finishes, the software will open the output path automatically to let you check the new converted video file.
OK, now you can download the elegant tool to have a try by yourself. You'll enjoy playing with it.
Good luck!!!
If you need complete detail, please visit http://www.nunufashion.com/software/SW_Tutorial.aspx?swid=20.
SPAM
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
What format to convert video for cell phone (LG Chocolate)
By V Bot in forum Portable VideoReplies: 4Last Post: 16th Aug 2012, 18:04 -
Do you use a cell phone?
By johns0 in forum PollsReplies: 12Last Post: 23rd Jan 2012, 23:39 -
Cell Phone Shut Down During Video and Video Won't Play
By Chief4Life in forum Newbie / General discussionsReplies: 13Last Post: 17th May 2011, 22:26 -
Wanna Play HD video Clip on my cell phone !
By augustya in forum Video ConversionReplies: 6Last Post: 3rd Oct 2010, 10:43 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 15:09
