Results 1 to 9 of 9
    Jun 2006
    Argentina
    Hi! Iīm really a newbie I just got a camcorder the sony HC96 and I canīt work this out. When I see the video in the TV itīs great, but when I capture it on the PC itīs so small, and when I want to see it full screen itīs obviously awfull, very pixelated. What is that Iīm doing wrong? How can I keep that great video quality that I have on TV on my pc, so I can edit it and make a DVD?? I hope you can help me, either give some tips or just a tutorial to read, I know this is basic but Iīm really lost. I usually use pinnacle for editing/capturing, this time I also tryed the software that comes with the cam.
    Thanks for your help!!
    Oct 2005
    666th portal
    use windv and a firewire(ieee1394) cable to transfer the miniDV tape to your computer. it will be about 13GB per hour of tape. same quality as on the tape.
    Apr 2003
    Maryland
    You are obvioussly capturing at a very smalal resolution and hiigh compression
    Check your capture program and make sure you are capturing / Transfering at full res DV
    which should be 13 gigs per hours as previously mentioned.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  4. You are probably capturing via the USB port. USB 1.1 (what your camera has) isn't fast enough to send the full DV stream. So you are getting a more compressed, scaled down video. You must use the ieee 1394 (aka Firewire or iLink) port to get full DV video.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The HC96 doesn't seem to be such a crappy camcorder as you make out from its reviews. Sorta better than average.
    So, could it be an operator error? Naw, the customer with a wallet is always right.
    http://www.camcorderinfo.com/content/Sony-DCR-HC96-Camcorder-Review.htm
    http://www.kiva.org/about
    Mar 2004
    Texas, USA
    The first thing to understand is that your computer screen has much higher resolution than the video, even if the video is captured at full resolution. The video at full resolution is 720 by 480 (if NTSC, 720 by 576 if you have PAL video, which you probably have). That's either a small window on your PC, or if expanded to full your PC screen, very pixellated. Not to worry, since it will look fine after transferred to DVD or back to tape to play on your TV. But do make certain that you are getting full resolution into your PC.
    Steve
    Jun 2006
    Argentina
    OK, I will get that firewire cable tomorrow and see how it works! I let you know!
    thanks a lot!
  8. Be sure your computer has a firewire port. If not, you'll have to buy a firewire card too. Decent ones run $10 to $20.
    Jun 2006
    Argentina
    Hi all! I bought the firewire cable and everything works great, so thanks all!!
