I am trying to load an AVI file into Windows Movie Maker (it fails in Media Player 10 too for that matter) and I get the message:
vts_01_1.avi cannot be imported because the required
codec is not installed on your system.
Useful isn't it.!
Now unless I go out there and install every codec under the sun - I have no idea which codec I need.
I did download a utility to analyse missing codecs from videohelp, (forgotten the tool) but all I got was a list of about fifty codecs - How do I know which one I need?????
Please someone help me with this codec lark.
Thanks in advance for any feedback.
codec is not installed on your system.Must have been extracted from a DVD and converted to AVI. The first main movie VOB in a DVD is called VTS_01_1.VOB. But no matter.
Gspot should tell you what you need. You are probably missing the Xvid codec.
If you want to make things easier as far as codecs and playing, try VLC Media Player instead of WMP. It uses it's own codecs, plays about everything, is freeware and very configurable. -
It was the Xvid Codec - Many thanks.
I now realise how to use GSPOT
Thanks everyone for the helpful feedback.
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
