Hi, please can someone advise on my problem. A friend has given me a copy of a short film he's made in .AVI format. It works fine on the PC, but I've been trying to convert it to DVD to enable the family to watch it on TV. I've tried using Main Concept MPEG Encoder; AVI DivX to DVD, SDVD, etc; Easy AVI to DVD, SDVD; MPEG 4 Direct Maker; and AVI to DVD Converter......most were trial software...trying to determine which would work. All the software programs either gave me an error message, informed me that there wasn't any video content or just froze and I had to manually "End task". The film info that appeared in MPEG 4 Direct Maker, before the error message, was:
Video: 640 x 272; 24.9999996076687 fps
Audio: 48000Hz Stereo
Original Video Codec: XVID
Original Audio Codec: MP3, bitrate: 136Kbps
Any advice would be greatly appreciated.
Mike
Go here https://www.videohelp.com/tools?tool=vso_DivXtoDVD
scroll down the page a bit and download the free version. This tool works with most formats, and has good to very good qualitymember since 1843 -
I would recommend DivxToDVD also for an easy conversion. That's a very odd framerate.
That could be part of the problem. I would check it with Gspot 2.52 to see if that is correct. If you get nowhere with DivxToDVD, drop it into VirtualDub Mod and re-encode it and change that framerate to 29.97 fps. You could also change the frame size to 720 x 480 by adding borders. Watch out for MP3 VBR audio also, most MPEG encoders choke on that. VDM will tell you if it's there. Besides just encoding it, you need to make the video and audio DVD compliant, then author it to the DVD format. For more info about the DVD format, see 'What is' DVD to the upper left. <<<<<<
These are NTSC compliant specs - the OP is in South Wales (that blob on the left side of the UKOriginally Posted by redwudz
), and so is in PAL-land.
@ Mike_EH: If you do jig the video around in one of the VirtualDub tools, you'll need a framerate of 25fps and a resolution that is PAL compliant - one of: 720 x 576, 704 x 576, 352 x 576 & 352 x 288. Given the original resolution (640 x 272), I'd be inclined to try either 704 x 576 or 352 x 288 and see how they come out.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi, again. Thanks for all the advice. When the swelling to my eyes has gone (flippin' hayfever - I hate it) I'll get down to trying Virtual Dub. I just can't look at the monitor for any length of time at the moment.
Thanks again
Mike -
Hi, again, thanks for your advice.....dunnit, flipping well dunnit. I'm so happy I could start singing...........Mike
Carpe diem.
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 09:04 -
DVD to .avi problem
By poir420 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2010, 17:12 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 14:55 -
Avi to DVD problem
By slipknotkod in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 01:57 -
dvd to avi problem
By hobmob in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 17:40
I was looking at the framerate reported. I see now that it's probably 25fps with a little error in the measuring. But
