Am posting this topic for my brother who has a 42" Samsung SP42 W3 HFX rear projection TV - Appologies if this is in the wrong place. Anyway, a few days before Christmas it needed fixing. I think it was the convergence board that went on it. It cost £150 to fix and is still not proper. The repair man described it as watchable when he returned it - which it is but only just.
The image is now slightly bigger than the viewing area so part of the picture (top & bottom) is missing - very annoying when watching cricket or darts as the score doesn't show.
Also, the picture isn't straight in places - it's as if it's being pulled up and down at different points along the edge of the picture.
When you access the perfect focus setting it says "No sensor data" and then goes straight back to the TV picture which it didn't do before.
Anyway, have heard that there's a service menu on this TV which is accessable by entering a code on the remote control. Does anybody know the code for this model? I'd like to have a look at the settings to see if there's anything that can be adjusted to fix the two problems listed or at least make them better.
TIA
	hi andyg
 put your tv in standby, then on the remote press
 display then
 menu then
 mute then
 power
 you should be in the service menu now, when your in there i would write down the numbers on the right hand side off the screen before you change anything so you can but it back if it is wrong.
 cheers phil
	I have the same problem with my samsung HC-P4252W, does anybody know access code for settings.
  Rear projection HD tv picture faultBy Stedalton in forum DVB / IPTVReplies: 0Last Post: 22nd Jun 2010, 13:16
  Connecting PC to Sony rear projection TVBy seminolemuscle in forum Newbie / General discussionsReplies: 10Last Post: 24th Feb 2010, 00:03
  rear projection looks like convergence is off but it's not..By BroomQueen in forum DVB / IPTVReplies: 0Last Post: 9th Dec 2009, 20:45
  Need solution on my New Rear Projection TVBy tony1960 in forum DVB / IPTVReplies: 14Last Post: 15th Jul 2008, 19:36
  Rear Projection TV HelpBy Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 00:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
