Hello.
I tape Pro Wrestling events on two MiniDV cameras.
I have captured the events to .AVI(almost 2gbs each wrestling match!) and have begun multi-cam'ing and such on Premiere 6.5
I want to burn these to DVD when i am done with them.
How would i do so? And how much would the file size be? The event i am doing right now is about 3hours long and i know it's going to have to be two discs. They only save to .AVI so am i going to have to convert the .AVI to DVD format again later? I have a 160GB hard drive w/ only 25GB space empty (and that's with the other events captured)
Thank you so much.
Premiere 6.5 doesnt have the export to dvd option??
if not, u have to use an encoder to get an mpeg2 format out of the avi. (adobe encoder should be with ur premiere application). if not, check this link.
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=AVI+to+DVD&...+or+List+tools
VERVEGod Bless Lebanon... -
Debugmode frameserver will allow you to frameserve from the Premiere timeline to a standalone encoder. This means you don't have to export to DV avi, simply export a small signpost file from which to encode.
Read my blog here.
Premiere v6.5 has a buit in MPeg2 encoder.
Get the free 1.3 update at the Mainconcept site
http://www.mainconcept.com/adobempeg.html -
Thanks guys.
Do any of you know how much space 2-3hrs worth of stuff will take? -
DV formatOriginally Posted by tokyomask
2hr 27GB
3hr 40.5GB
MPeg2
Depends how much your eyes can take.
Per https://www.videohelp.com/calc
2hr 4853Kbps wth 224Kbps audio
3hr 3159Kbps wth 224Kbps audio
Gettting down low for 720x480
for 352x480 divide bitrate by 2 and then add back all you can
mini laptop questions
By vhelp in forum ComputerReplies: 18Last Post: 9th Dec 2019, 12:36 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Pro CS5 - 2 Questions
By Anonymous8443434 in forum EditingReplies: 20Last Post: 22nd Jun 2010, 22:30 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Mini DV questions
By SpeedyProductions in forum MediaReplies: 8Last Post: 5th Aug 2008, 13:55
