  1. How do you de-multiplex and then re-multiplex an MPEG1 file with bbMPEG?? I've studied the program, and the help files, and I'm buggered if I can figure it out!
  2. According to that, bbMPEG won't de-mux the MPEG1 file and I have to use the MPEG Tools section of TMPGenc first. Is this correct? Will bbMPEG not de-mux? The only reason I chose bbMPEG was that it is supposed to be the best "muxer" available.
    Feb 2001
    Berlin, Germany
    bbMPEG wont de-mux the MPEG files. There is a command line based bbDMUX tool, that comes with the bbtools pack. Probably you will find it at http://www.doom9.net if you like. I use to demux with TMPG and remux with bbMPEG.
  4. Thanks.
