Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Hi
    I would like to know how can I delete one track of a stereo sound file (right or left) using goldwave.
    I try to find it in the menu or the help but could not
    So if anyone can help
    thanx
  2. Check for Channel Converter (Stereo->Mono) or a menu similar to that
  3. That was what I was looking for but could not found
    this is why I ask the pro user of goldwave to give a little help
    Aug 2005
    Right here
    You may want to try this:
    Copy the channel you want to keep, then open a new (mono or stereo project, as needed), and paste. Save new wav.
    Cheers
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
    Apr 2003
    Largo, FL
    Another way- select the channel you don't want and reduce the volume to zero (or just click the 'delete' button). Then click 'save as' and select 'mono' in the attributes box.
  6. Oh great
    thanx for the tip
    Jun 2006
    In the edit menu choose channel then select the track you want to delete. Make sure the entire track is selected then hit delete on your keyboard. Then save the file as a mono file. You will have a mono track. If you want a stereo track with a channel that has no sound you could save it as a stereo file.
