I am interested in buying a LG GSA-4082N DVD Burner for my laptop but can't find it. Has it been released or where can I buy it? As well, will this work in a Toshiba Protege M400 TabletPC?
If in the US:
Essentially the GSA and GWA are the same drives hardware-wise. The GWA is the oem version. They generally differ from their retail (GSA) cousins in that they do not have DVD-RAM support. Not exactly sure why Newegg sells the oem rather than the retail.
You may purchase here: http://www.newegg.com/Product/Product.asp?Item=N82E16827136070
Not sure but I would suspect that drive to fit any Toshiba laptop. You could call Newegg and confirm before purchase. Good luck.
EDIT: My statement above about GSA vs GWA being roughly equivalent hardware-wise applies to this model (4082N). Some gsa/gwa's with the same model number do not share the same hardware.
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 02:39 -
Cant update my LG GSA-55L firmware?
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jul 2007, 08:59 -
Question about GSA-E60L External
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 20th Jul 2007, 12:27 -
Video capture with LG GSA-5169D
By henrik.uggla in forum LinuxReplies: 2Last Post: 25th Jun 2007, 16:59
