Hello. Im just curious how to put 13 episodes or more .avi's to a dvd...Time is at 24 to 25 mins filesize range from 230-250mb... How do I do this? What programs should I use... Thanx in advance...
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm walks you through the process using TMPGEnc Plus.
Around 3 hours means Half D1 (352 x 480/576) is probably your best bet.If in doubt, Google it. -
Yes but VCD resolution is ... shit.
Half D1 is a decent resolution choice and can give really good quality at 3 hours and even decent quality at 4 hours.
The 4 hour mark though is really about the limit of good quality with Half D1 resolution.
So forget about getting more than 3 to 4 hours per a single layer DVD disc.
Put 4 Sopranos episodes from 2 DVD5 to 1 DVD9
By audax in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2012, 02:23 -
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 08:56 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 17:37 -
vob to avi (tv episodes)
By stewart2000 in forum DVD RippingReplies: 13Last Post: 27th Sep 2008, 06:05 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 16:09
