i want to link my dvd player to my surround sound system which has dts. What is the best way to connect - optical cable or a coaxial cable? I thought optical was the best connection but apparently What Hifi have tested them both and found coaxial sounds better.
ta
Results 1 to 17 of 17
Personally I find both are about the same. I had a sony dvd player with a optical out and used that for awhile. Now the dvd player I'm using only has coaxial out and it sounds just about the same.
I'd say it doesn't really matter pesonally. The best thing is whatever works for you. If you have both types of outputs on your dvd player and both types of inputs on your receiver just do a comparison on your own.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
As far as connectivity goes, they are equal. The differnce would be in the dvd player itself, the cables, or the receiver.
As yoda313 suggested, try them both and see what works best for you.Google is your Friend -
i would give a slight edge to optical , though they tend to fall out
They are both the same signal wise there is no audible difference at all.
One advantage of optical is that it is electrically isolated. This prevents a potential ground loop which can sometimes introduce hum into the system.
Originally Posted by davideck
For short distances (under 25ft), performance is about equal. -
ground loop problems can happen on lenth of cable , even 1 inch ....
digtial coax is supposed to be 110 ohms impeadance, though most is 75ohms , not really a major issue in consumeer equipment ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ground loop is an analog only problem, it does not affect digital signal.
Reviews I have read seem to indicate that this is one of those areas where theory does not always translate into the real world.
Just like some units that show better quality video thru composite, when S-video should be better, it comes down to the quality of components used in the particular hardware you happen to have.
Theoretically, aside from electrical issues, they should be the same. In the real world, with actual testing, they most definitely are not, at least not always. Some units had better coax, some had better optical.
So it comes down to testing your particular setup and deciding for yourself. But remember to retest if you change either your input or output device, this changes the equation. -
Originally Posted by SingSing
a ground loop can add a hum to your system even when switched to a digital input i assure you .... it doesnt always happen , but happens enough ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Don't worried. That's not a type of mistake that engineers will made. Digital ground is always decoupled from the analog ground.
on consumer equipment - the shield is electrically the same as the shield on the analog .... test it out
Originally Posted by BJ_M
http://www.elect-spec.com/faqgrdl.htm
Originally Posted by SingSing -
both are equal in terms of sound quality if the proper cables are used. i bought a panasonic 5 disc changer last year and was amazed that there was no optical output...but...the coax signal is just as good....
Analog ground and digital ground merge into system ground (which can be chasis/shield ground) via inductors and common mode chokes. These are well understood by designers. These circuits have very very low Dc resistance, and measured like shorts on an ohm meter.
If the receiver can't do this right, then it should have a lot of other problems. It should not able get thru production floor, which actually has many kinds of ground issue, and operate by unskilled ( known as off the street ) labor. -
SingSing, i designed/install millions of $$ worth of equipment into studios and every other type of venue you can think of -- ive ive seen plenty of ground loop problems on both Digital and Analog and mixed systems .. and this is on some of the best equipment in the world .... it most often happens when good grounding practise is not followed by either the designers or the installers before im there....
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
coaxial on P2370HD samsung
By abdelilah in forum DVB / IPTVReplies: 1Last Post: 4th Jun 2011, 17:08 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Digital optical vs. digital coaxial cord
By coody in forum AudioReplies: 3Last Post: 12th Dec 2009, 08:57 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
