I have a problem in replacin a subtitle in DVD movie (with keeping the menu).
the DVD has 3 subtitles "english" "french" "spanish" and i want to change the "french" to "hebrew.
I manage to change it by following this tutorial:
https://forum.videohelp.com/viewtopic.php?t=275603
and in the "remuxed" folder i can see all the subtitles ("english" "hebrew" "spanish") but when i use "VobBlanker" to reauthored the movie i get only "english" and "spnish"(instead of "hebrew") and the "french" is gone.
When i open the IFO of the original movie in "VobBlanker" i get this error:
Pleas help me![]()
Try going to, File ==> VOBs Full Scan. I don't know if that'll help you but it's worth a try.
Hi-
It has ILVU. It's probably multi-angled, which VobBlanker doesn't handle. Which angle did you use PGCDemux to get (the default first one, I would guess)? Strip out the other one(s) from the DVD, and try again.
It says you might have playback problems, and you did.
Problem With VobBlanker
By ramimahafza in forum Authoring (DVD)Replies: 1Last Post: 26th Jun 2011, 00:35 -
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 01:52 -
Vobblanker error
By pcb in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2010, 13:16 -
VobBlanker
By jjis in forum DVD RippingReplies: 2Last Post: 5th May 2010, 18:03 -
Problem with Vobblanker
By m-man in forum EditingReplies: 8Last Post: 29th Jan 2008, 16:58
