Do Mac's need to be reformated and if so, how often?
I consider reformatting a very last resort to computer trouble. Too much trouble to go through unless you absolutely have to.
I did reformat when buying a second-hand G4 some years ago, to start fresh from whatever the previous owner left behind. I also did a fresh system install after buying a bigger boot HD. I wouldn't do it for regular maintenance. -
what kind of problems are you having?
As Case pointed out, this should be considerd a drastic last resort.
Other things that are easier to do and fix most of the problems
that you can encounter on a mac can be fixed by running
diagnostic tools such as DiscWarrior and Disc utility,
or by running System maintence tools such as
Onyx or Cocktail or Macaroni."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
The only time I really reformat is when upgrading the OS to a major new release (ie. Jaguar>Panther>Tiger).
Usually problems are User related (preference, caches etc.) - and if the problems persist with a freshly created user account only then a reformat might be in order.
But you are creating daily backups/clones (with SuperDuper! or CCC) to an external Firewire drive daily
it'd be easy to revert to a working stable clone if something did get stuffed.
Can't Render Videos Properly After Reformat
By abdullahisme in forum EditingReplies: 7Last Post: 12th Apr 2011, 08:50 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 08:36 -
Problem w/Folder sort v1.1. Had to reformat disk
By cal_tony in forum ComputerReplies: 2Last Post: 24th Aug 2009, 15:25 -
reformat computer - no sound
By jyeh74 in forum ComputerReplies: 18Last Post: 1st Jul 2009, 18:56 -
Reformat Hard Drive, HELP!!
By danl_9x in forum ComputerReplies: 27Last Post: 4th Jun 2008, 12:39
