I have had two cases of SVCD disks starting to fail. These played perfectly several times and don't show any physical damage (scratches or fingerprints). They play along for a while, then produce large blocks and freeze. I can often play the sections before and after the problem area. After problem develops, disk will also fail on computer.
The player is working great with all other disks. Is it possible for the DVD laser to corrupt the data on a CD-R?
CD-Rs are Hi-Val 650MB and player is Pioneer 343. Anyone else see this problem?
I never used Hi-Val nor Innovation CDRs. They are not good in quality (last long). I only use them (when they have rebate to final cost=$0) for burning a test CD. After seeing my final product worked, I then use a better quality CD for my final and archived.
I don't think the laser corrupt your data, but the head in the drive can cause the label to get bubble and that's it. Your data is stored on the otherside of the label (not the otherside of the CD). The label got protected by a thin plastic which made you think that you data was written on it (the plastic).
If you buy a bulk blanks CD, sometimes you see a clear plastic on the top. That's the one which cover on top of your data.
Hopes this answer your question. Goodluck
// bachkhoa -
Your symptoms describe what happened to me when I burned at too high a speed. This is probably a combination of cheap CDR's, burning speed and possibly some form of corruption. I slowed my burning speed to 2x and havent' seem a hint of a problem since then.
Regards,
Roveer
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 22:06 -
Looking For A Remote For A Pioneer Laser Disc Player
By DJboutit in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2010, 17:43 -
Hard disk damage or corrupt boot manager? [Solved]
By Sakuya in forum ComputerReplies: 15Last Post: 5th Jun 2010, 00:33 -
Corrupt Video Files on hard disk
By gooberguy in forum EditingReplies: 1Last Post: 26th Mar 2010, 02:55 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15
