Hello ! I have a lot of MPEG movies and i need to watermark them all , but i do not want to change the proporties of the movie ( w x h , bitrate, etc ... ) . Can you recomend me some software ? Or how is it done properly ? Thanks in advanced ...
Water-marking requires re-encoding each frame... So something's gotta change.
You can maintain the original resolution and bitrate simply by setting your encoder correctly, however there is a good chance that there will be some reduction in quality due to the re-encoding. How much will likely vary from the clip to clip. As has been pointed out, there is no way to do this without re-encoding every clip.
MPEG movies is pretty broad. Are these DVDs, VCDs, isolated clips ?Read my blog here.
Hmmm so i have to encode each frame ... ok , so what software can i use ?
P.S. What software can i use to "view" clip proporties ( bitrate , etc ... ) -
A) VirtualDubMod (or AviSynth) + any mpeg encoder you can frameserve to
B) GSpot (2.52 beta or later (if such exist))
/Mats -
jimmalenko has written guides on using the logo filter/watermarking.
/Mats
Adding a watermark to an mpeg-2 video file
By bobzy20 in forum EditingReplies: 5Last Post: 17th May 2011, 15:15 -
Mencoder watermark help
By MisaN in forum Video ConversionReplies: 0Last Post: 24th Aug 2010, 12:01 -
Watermark with FFmpeg ?
By Endemoniada in forum Video ConversionReplies: 1Last Post: 22nd Aug 2010, 04:08 -
Watermark on videos?
By DVDHelpPlease in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2010, 23:18 -
WATERMARK help!
By legendvij in forum SubtitleReplies: 9Last Post: 13th Feb 2008, 01:52
