  1. Member isogonic's Avatar
    Jan 2003
    @localhost
    can anyone id this, it came in the bag of screws with my computer case. flat end is to plugin, other end is round with a hole in the center. never seen one
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Looks like a power supply cable maybe for a Front USB ports....
    Mar 2003
    Canada
    The flat end is the same as the connection which connects the case speaker to the motherboard. It might be some kind of adapter if you have a case with a non-standard connection for the speaker.
