i have streambox ripper which usually used to convert my real audio files to mp3. All of a sudden it has stop converting the real audio files. It keeps giving me an error stating that i need some G2 codec. Is this because i have installed a new real player that uses a dll file which streambox ripper does not understand?
please help me with this problem
How's My English?
The Real to ??? converting version of Streambox Ripper is no longer supported. You may have to go to http://oldversion.com/program.php?n=real and get an older version of Real to make it again work. This may not work for all Real audio, because they have no doubt upgraded their encoders over the years. FWIW, I use Total Recorder and just capture audio streams myself.
so besides the total recorder is there any alternative. Is there anything out there that can convert the real audio files
How's My English? -
what other programs can convert real audio to mp3 or wma
How's My English? -
You can try dbpoweramp (current shareware version, or earlier free version), with the RealAudio codec installed. I used to use a utility called 'ra2wav,' a long time ago, if I remember correctly, but that probably only worked for the early .ra files.
If you can play them in WinAmp, you can also use WinAmp's Disk Writer plugin to convert as well, in theory.
If all else fails, you can always have something like Audacity record the audio while you play the Real files.If cameras add ten pounds, why would people want to eat them?
ImToo DVD Ripper problem
By -phenom- in forum DVD RippingReplies: 2Last Post: 9th Aug 2010, 10:52 -
A little help finding the right ripper for me, please?
By Cygnus111 in forum DVD RippingReplies: 4Last Post: 9th May 2010, 11:27 -
Xilisoft Blu-Ray Ripper - Subtitles problem
By Mister Epic in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2009, 10:52 -
best cd ripper
By jason in forum Newbie / General discussionsReplies: 20Last Post: 14th Apr 2009, 15:32 -
problem with the ripper
By chuky in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 12:15
