I have successfully ripped (Smartripper 2.xx), encoded (TMPGEnc 2.02), and created (Nero 5.5.5.1)a SVCD but the playback is choppy (delays between frames). Used Tmpgen and I'm looking for some specific settings that someone has used to create a smooth creation. Could it be because I used automatic VBR?
Either you did convert the framerate or the total bitrate is higher than your dvd player can handle, I believe.
Hi!
What's your player?
My Pioneer DV-444 absolutely hates ANY SVCDs that are encoded with Variable Bit Rates - high or small.
Video is cool but the audio is so choppy that there's more silence than audio!!
VBR on VCD is a bit weird too - audio is delayed.
If lowering your average bitrate (VBR on SVCD) doesn't help, try encoding using a Constant Bit Rate.
A bit of a drag I know but your player might not be up to VBR!
Sue xxx.
Any way to keep smooth mpeg2 playback with Handbrake?
By Forty0zFreedom in forum Newbie / General discussionsReplies: 11Last Post: 26th Apr 2012, 16:58 -
filter to smooth playback?
By kinglerch in forum EditingReplies: 14Last Post: 21st Oct 2011, 14:17 -
DVD to MP4 conversion playback not quite smooth.
By scottb721 in forum Video ConversionReplies: 1Last Post: 21st Jun 2010, 10:45 -
How to test smooth x264 1080p playback?
By tsoukkis in forum Software PlayingReplies: 1Last Post: 26th Oct 2009, 07:43 -
WMV settings for smooth playback
By sumario in forum EditingReplies: 0Last Post: 3rd Jul 2008, 21:31
