Love convertxtodvd, great product, especially like the crude menu feature. But when I select multiple AVI files it converts them in the wrong order that they were selected. I tried adding two AVI file and selected them both one by one and also have tried selecting them together and they get encoded in the wrong order. The first avi file is listed first and it does say it is encoding the first file as soon as the converting starts but when I burn the DVD they are backwards. Anyone else have this problem? Please help I don't want to go back to monkey crap WinAvi, don't get me started on there latest version which crashes every time I try to encode the same files which work fine in Convertxtodvd, plus there buttons in their UI are not spelled correctly, pretty un-professional.
Are you using convertxtodvd or Divxtodvd ?
With convertxtodvd you can set the order before converting using the up and down arrows next to the list of avi files. just select one, and shift it up or down the list. Repeat with the others until they are in the order you want, then hit the convert button.
I believe the order issue is actually a windows selection problem, as many programs put the last item first when using the standard windows selection dialogue.Read my blog here.
I'm using convertxtodvd 2.0.12, they're definitely listed in the correct order in the selection window. I've tried selecting them one by one and selecting them both at the same time. I've used other programs like DVD Santa that get our of order like you mentioned and I simply re-order them but these files are listed in the correct order.
Is there a program that will played the encoded (video_ts) files before I burn them so I can check them out and not waste DVD's.
Thanks -
it may be doing them alphabetically. try renaming them 1.avi and 2.avi ..... stranger things happen.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
burn multiple video files on 1 dvd using ConvertXtoDVD
By sascha_ in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 07:09 -
ConvertXtoDVD 4 gives error when authoring multiple titles
By Sikander in forum Authoring (DVD)Replies: 7Last Post: 10th Jan 2010, 20:05 -
convertxtodvd multiple avi files
By ladysox in forum Video ConversionReplies: 3Last Post: 20th Mar 2009, 18:18 -
Converting multiple files with convertxtodvd
By aruwin in forum Video ConversionReplies: 6Last Post: 29th Jun 2007, 05:27
