I was just wondering if there was a program available that will allow you to use your PC's capture card to record things that have macrovision protection without the distortion lines coming through. Just curious.
I have read about software modifications to ATI's software that can allow you to do this, but I am not an ATI fan at all and I don't keep up at all with their stuff, so I can't tell you what models this software supposedly worked on or where to find it. A carefully constructed websearch should help.
I have never tried this and I don't own one, but supposedly a Time Based Corrector (TBC) inserted between the video output and the recording device will remove Macrovision. -
The rf modulators handle this problem, but for the same price you can buy a dvd burner, rip the movies to the hard drive and have a much better end product.
If you capture you will not only lose the video quality but you will be stuck with .mp2 audio or .wav audio unless you re-encode. On top of that, a capture of a dvd would take the duration of the movie, where a rip would take you about 10-15 min. -
Originally Posted by greymalkin
I have ripped plenty a movie. I have a really old system so it takes a couple of hours... This was more of a side project kind of thing.
So really, a regular RF modulator will get rid of macrovision?? -
Maybe but it will be lower quality than a TV tuner capture.Originally Posted by djackson75
I'm not really too worried about picture quality, just more about getting rid of the Macrovision.
Not all computer based capture cards recognize macorvision ... some ignore it.
The Hauppauge WinTV PVR line is that way ... it will record anything.
ATI card's Macrovision detection can be defeated with software hacks on the pre-9000 series, and/or a Sima Copy Master or similar device. This is NOT a TBC, but provides the Macrovision removal.
If you have the capability to rip the disk, time-consuming or not, I cannot imagine accepting the quality loss from a capture of a DVD. Having done both, the difference is huge. Only time I resorted to this and kept the result was an ungodly complicated disk which I could not rip in its desired sequence. It had a huge number of files and a randomized playback structure..
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum Capturing and VCRReplies: 11Last Post: 23rd Aug 2012, 12:19 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 20:00 -
If a DVD player has no Macrovision…
By coody in forum DVD & Blu-ray PlayersReplies: 20Last Post: 17th Jan 2008, 18:20 -
need Macrovision free DVD player
By bxd20 in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Oct 2007, 13:30 -
Capture card w/scriptable commandline app & macrovision warning?
By miamicanes in forum Capturing and VCRReplies: 2Last Post: 9th Sep 2007, 12:31
