Hi, At the moment i am using Cucusoft AVI to VCD DVD MPEG Creator Pro and that seem to be working correctly becaus I can play the movie using Nero Showtime. I have tried using the burner which comes with the the cucusoft software but that comes up with the error message saying:
"15:08:25 Begin to Burn Disc.
15:08:25 Read parameters file ok.
15:08:25 Init DVD Video Parameters.
15:08:25 CDROMControler.BurnVideoDVD: Formatting directories...
15:08:25 CDROMControler.BurnVideoDVD: Formatting files...
15:08:25 CDROMControler.BurnVideoDVD: 160 MBs of cache will be used during burn process
15:08:25 CDROMControler.BurnVideoDVD: Probing SCSI address 1:0:1:0 for CD/DVD burner device...
15:08:25 CDROMControler.BurnVideoDVD: Found CD/DVD device 'HP ' - 'DVD Writer 200j ' - '1.72' with 2097152 UCHARs of cache
15:08:25 CDROMControler.BurnVideoDVD: Probing supported write modes...
15:08:25 CDROMControler.BurnVideoDVD: Track-At-Once: Yes, Session-At-Once: Yes, Disc-At-Once PQ: No, Disc-At-Once raw P-W: Yes
15:08:25 CDROMControler.BurnVideoDVD: Testing unit ready...
15:08:25 CDROMControler.BurnVideoDVD: Getting BUP (Buffer Underrun Protection) support...
15:08:25 CDROMControler.BurnVideoDVD: BUP (Buffer Underrun Protection) Enabled: Yes, Supported: Yes
15:08:25 CDROMControler.BurnVideoDVD: Enabling BUP (Buffer Underrun Protection)...
15:08:25 CDROMControler.BurnVideoDVD: Setting maximum supported CD/DVD speeds...
15:08:25 CDROMControler.BurnVideoDVD: Getting current CD/DVD speeds...
15:08:25 CDROMControler.BurnVideoDVD: Current read speed 10816 KBps (10816 maximum)
15:08:25 CDROMControler.BurnVideoDVD: Current write speed 3380 KBps (3380 maximum)
15:08:25 CDROMControler.BurnVideoDVD: Getting track information...
15:08:25 CDROMControler.BurnVideoDVD: Track blank: Yes, NWA valid: Yes, free LBs 2295104, NWA 0, track number 1
15:08:25 CDROMControler.BurnVideoDVD: Getting disc information...
15:08:25 CDROMControler.BurnVideoDVD: Disc erasable: No, Disc status: 0x00, Last session status: 0x00, Disc type: 13
15:08:25 CDROMControler.BurnVideoDVD: Burning 4285446144 UCHARs of DVD-Video image
15:08:25 CDROMControler.BurnVideoDVD: Sending OPC (Optimum Power Calibration)...
15:08:41 Failed!
15:08:41 CDROMControler.BurnVideoDVD: Writing the stuff to the CD/DVD disc >>>
15:08:41 CDROMControler.BurnVideoDVD.CB: Target file analyze begin
15:08:41 CDROMControler.BurnVideoDVD.CB: Target file analyze end
15:08:41 CDROMControler.BurnVideoDVD.CB: Wait cache full begin
15:08:44 CDROMControler.BurnVideoDVD.CB: Wait cache full end
15:08:57 CDROMControler.BurnVideoDVD: StarBurn_CdvdBurnerGrabber_DVDVideoTrackAtOnceFrom Tree() failed, exception 8, status 0, text 'CStarBurn_ScsiTransportASPI::ExecuteCDB(): Command failed'
15:08:58 CDROMControler.BurnVideoDVD: EXITing with success
Then I read on this forum to convert the avi files to DVD where it is in the Video and Audio folders and then use nero burning rom to burn the video. This is the log from the error which i get when burnign using Nero. I have recently updated by firmware to the ighest i can find.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Nero 7 Ultra Edition\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 13:54:32
NT-SPTI used
Nero Version: 7.2.0.3
Internal Version: 7, 2, 0, 3
Recorder: <HP DVD Writer 200j> Version: 1.72 - HA 1 TA 1 - 7.2.0.3
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <JLMS DVD-ROM LTD-166S>Version: DPS2 - HA 1 TA 0 - 7.2.0.3
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800AB-22CBA1 atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP1203N atapi Port 0 ID 1 DMA: On
CdRomPeripheral : JLMS DVD-ROM LTD-166S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HP DVD Writer 200j atapi Port 1 ID 1 DMA: On
CdRomPeripheral : PT1842Z DZV922T 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
JLMS DVD-ROM LTD-166S F: CDRom0
HP DVD Writer 200j G: CDRom1
PT1842Z DZV922T H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048044kB)
Free physical memory: 571MB (585596kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.6.2006
UDF/ISO compilation
14:12:25 #1 Phase 112 File dlgbrnst.cpp, Line 1730
DVD-Video files reallocation started
14:12:25 #2 Phase 114 File dlgbrnst.cpp, Line 1730
DVD-Video files reallocation completed (no file modified)
14:12:25 #3 Text 0 File Isodoc.cpp, Line 6424
UDF document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
14:12:25 #4 Phase 111 File dlgbrnst.cpp, Line 1730
DVD-Video files sorted
14:12:25 #5 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
14:12:25 #6 Text 0 File Reader.cpp, Line 124
Reader running
14:12:25 #7 Text 0 File Writer.cpp, Line 113
Writer G: HP DVD Writer 200j running
14:12:25 #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
14:12:25 #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
14:12:25 #10 Text 0 File Burncd.cpp, Line 3365
Turn on Disc-At-Once, using DVD media
14:12:26 #11 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2092511 (465:00.11, 4086MB)
14:12:26 #12 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD)
14:12:26 #13 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: HP DVD Writer 200j, Media type: DVD+R
14:12:26 #14 Text 0 File DlgWaitCD.cpp, Line 473
>>> Protocol of DlgWaitCD activities: <<<
14:12:26 #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2092512 (2092512) = #2092512/465:0.12
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2092512 blocks [G: HP DVD Writer 200j]
14:12:26 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [G: HP DVD Writer 200j] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4285464576, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2092512 | lead-out | 1 | 0x41 | 0x00
14:12:26 #17 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
14:12:26 #18 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:12:26 #19 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
14:12:26 #20 Text 0 File Burncd.cpp, Line 4199
Cache writing successful.
14:12:26 #21 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
14:12:26 #22 Phase 28 File dlgbrnst.cpp, Line 1730
Speed measurement started
14:12:26 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:18:24 #24 Text 0 File WriterStatus.cpp, Line 116
<G: HP DVD Writer 200j> start writing Lead-Out at LBA 2092512 (1FEDE0h), length 0 blocks
14:18:24 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
14:18:24 #26 Phase 29 File dlgbrnst.cpp, Line 1679
Speed measurement completed: 8.6x (11,960 KB/s)
14:18:24 #27 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 2.4x (3,324 KB/s)
14:18:24 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2707
14:18:24 #29 SPTI -1066 File SCSIPassThrough.cpp, Line 290
G: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24
Buffer x0566ca00: Len x804
14:18:24 #30 SPTI -1066 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xF9 15 01 FF 00 00 00 00 00 00 00 00
14:18:24 #31 Text 0 File DVDR.cpp, Line 6541
Drive: HP DVD Writer 200j
Book Type request [gen]: DVD-ROM, write to EEPROM
Changing the Book Type was finished successfully, return code 0
14:18:24 #32 CDR -1207 File DVDR.cpp, Line 5676
Book Type automatically set to: DVD-ROM
14:18:24 #33 Text 0 File DVDPlusRW.cpp, Line 666
Start write address at LBA 0
DVD high compatibility mode: Yes
14:18:48 #34 SPTI -1046 File SCSIPassThrough.cpp, Line 290
G: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 30 05
Buffer x05950000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
14:18:48 #35 CDR -1046 File Writer.cpp, Line 302
Illegal disc
14:18:48 #36 Text 0 File ThreadedTransfer.cpp, Line 228
14:18:48 #37 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
14:18:48 #38 SPTI -1066 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 05 00 00 00 00 0C 00 00 00 00 24
14:18:48 #39 Phase 127 File dlgbrnst.cpp, Line 1730
Generating DVD high compatibility borders
14:18:48 #40 SPTI -1066 File SCSIPassThrough.cpp, Line 290
Sense Code: 0x24
Sense Qual: 0x00
14:18:48 #41 Text 0 File DVDR.cpp, Line 6541
14:18:48 #42 CDR -1066 File WriterStatus.cpp, Line 167
Invalid field in command
14:18:48 #43 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
14:18:48 #44 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25/04/2005 10:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\InCDfs.SYS': Ver=5, 1, 0, 5, size=102016 bytes, created 05/04/2006 11:34:04 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=5, 1, 0, 5, size=29568 bytes, created 05/04/2006 11:34:22 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=5, 1, 0, 5, size=8832 bytes, created 05/04/2006 11:34:56 (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
After buying Nero i found that it came with the NEro Vision software whcih i gave a go and took its times doing everything and then said not enough room on disk.
After this i tried to change the blank DVD disk which I am burning to because I did at first go for the cheapest PC line DVD+R and bought imation DVD+R and that hasnt made a difference because they still dont burn correctly.
If anybody has any sugestions then i would be listening and welcome
Sorry if this post is a bit too long and ware out your mouse roller ball, but out of the two logs which i have included i was unsure what was useful and what is not useful
Firstly : dvd
Audio_ts = nothing
Video_ts = your dvd content here (ifo , bup , vob)
Next :
Posssible cure :
Locating possible issue's will require returning to basic's on pc as follow .
Apear's pc may be getting off track with device release .
1: Disconnect all drive's (leave floppy if installed)
2: On ide0 , connect main hd with os , set to cable select , connect to end of ide0 cable.
3: On ide1 , connect dvd burner , set to cable select , connect to end of ide1 cable.
4: Restart pc .
5: Confirm basic burn setup by : Grab 1 x verbatim dvd-r , burn test at 4x .
If test fail's , possible cause's :
1: Alway's suspect media first ... try another brand .
2: Optical unit at fault .. alway's bios update when all else fail's .
Without another pc , or dvd burner , it would be impossible to tell if optical unit itself is at fault / faulty .
If test burn succesfull , conflict exist's with other optical unit's .
1: Connect second hd to ide0 (cable select) , connect to middle connector of ide0 cable .
Repeat burn test ... should be fine .
Once you have reached this stage , it's a possibilty the conflict is due to second optical unit connected to same channel as dvd burner ... may be faulty , need bios update ...
Of course there have been a couple of report's with this same error , all failing with same error ... possible this is a problem in newer version of nero ... may be issue of handling 2 optical unit's on same ide channel ... but you won't know that until you have done the "back to basic" test setup .
Of course ... hp unit's are not on most xmas list's either ... many complaint's ... consider sony / lg / pioneer if wanting to replace unit .
Liteon make good reader's , and fried frizbee's . -
I see you're using an HP200 writer with the latest firmware:
1.Is the media 2.4 or 4x rated?...it can't handle faster media.
2.Make sure DMA is enabled.
3.Can you burn CD's?...if so the DVD laser is fried(see 5),if not see 4.
4.Use a new IDE cable...they wear out after awhile.
5.The writer is tired...time to get a new one. -
I have tried most of the adivce given an i desided to change my software to the TMPGEnc DVD Author 1.6 and TMPGEnc 3.0 XPress.
Here the most stangest thing is i also changed the blank dvd i was using to start with and used a Sony DVD+RW after the sicknesses of keep wasting dvds and this worked correctly with no errors given when burning and worke don dvd player.
After this I then did the exact same thing with the software though used the blank DVD+R Pc Line and tried using imation DVD+R and the error message came up again on both.
This is the most strangest thing which has happened after check the connection and everyhting which you told me it must just be the DVD's i was using. Seems a bit of a waste though to be using DVD+RW to stored my DVD's on.
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 02:10 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 11:29 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 15:15 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54
