I manage to replace the subtitle by following this tutorial:
https://forum.videohelp.com/viewtopic.php?t=275603
But when i try to change the subtitle name in the choosing subtitle table
all i get is "Subpicture 2" and i want to change it to "Hebrew".
I tryed to change the IFO with "IfoEdit" but with no luck.
Please help me
If you followed that guide , those change's are made in both the video_ts.ifo , and vts_01_1.ifo (assuming ifo id) ...
In ifoedit , you have both ifo's loaded , close those + .
Click on video_ts.ifo ... look at subtitle's ... if subtitle language is not correct here , change and save .
Apply the same thing to vts_01_1.ifo as well , then save .
Play it again and see .
If still error , you may have applied the change's to video_ts.ifo and missed doing this to vts_01_1.ifo as well .
Remember all ifo's required the same change's when editing ifo's , and alway's save to apply those modification's .
Replacing subtitles
By tai in forum SubtitleReplies: 6Last Post: 30th Jan 2010, 11:20 -
Lost subtitles replacing PGC with VobBlanker
By *ale* in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2009, 13:17 -
Help w/ replacing an audio track on a DVD (w/o damaging menus, subtitles)
By svenge in forum DVD RippingReplies: 5Last Post: 29th Jun 2008, 02:37 -
Replacing .txt subtitles
By kpic in forum SubtitleReplies: 6Last Post: 20th Feb 2008, 08:11 -
Replacing only a few of the subtitles
By fledermaus in forum SubtitleReplies: 11Last Post: 9th Oct 2007, 11:56
