I'm converting cropped (720x432 with DAR 2.35:1) anamorphic PAL video to MPEG-4, at a fixed size (2CD's).
I could:
- Resize according to display aspect while maintaining height (1024x432 lanzcos), and then encode, or
Between these two options the same amount of data is encoded in each frame, but resizing is done before or afterwards. I was wondering if there was a quality difference, as in the first method we are encoding at a higher res, but lower bits per pixel, and the second a lower res but higher bits per pixel.
- Leave it at 720x432 and then encode (will be higher bits per pixel due to same file size), but then resize during playback.
I was thinking that the second option could be better due to a relatively higher amount of blocking (if some what indiscernable it's still there) with the first method at the higher res, and a lower amount of blocking in the second method then scaled up to the higher res without the blocking...?
Thoughts and critisism very welcome, as it seems to be the norm to resize beforehand, so I guess I want to see what it's like to go against the grain!![]()
Yes, you have the same amount of data per frame, but in one method you spread it over a much larger area. Coupled with resizing up - a quality reducing process in itself), the best option would be to resize during playback.
That said, the usually process is to resize down when encoding DVD to mpeg4, in order to maximise the reduced bitrate over a smaller image size.Read my blog here.
You also need to consider your playback device. Most set-top players will not play MPEG4 files over 720x480. Many will also not repect the PAR flag. If you want the greatest compatability you should reduce the frame size to 720x304 or 640x272.
Yeah great I was probably gonna go with just a vertical resize to 720x304 anyway, so what would be an advisable downscaling resize filter?
Best way to encode for playback on LG BD630?
By Davel23 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 17th Mar 2012, 19:14 -
Video Encoding Resize
By darkw1zard in forum EditingReplies: 7Last Post: 21st Oct 2011, 11:32 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 22:43 -
Why wont FairUse (or anything) resize not show on playback?
By zookeeper525 in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2007, 08:18 -
Resize Suggestion for AVI-DVD Encode
By Soopafresh in forum Video ConversionReplies: 10Last Post: 26th Jun 2007, 11:01
