I have a studioonline capture card on win2000 and I cannot have audio while capturing with virtualdub. The audio works ok with the bundled Studio. Can anyone help me ? Thanks.
I have the same problem with an ATI TV Wonder USB card. I have windows 98 SE. I also cant get the channels to change by opening MMC and changing them, then entering virtual dub.
this is off this webpage and helped me with audio problems but i had winTV card.
No audio in Virtualdub capture mode:
If there is no audio check that line in is not mute.(Double-click on the speaker icon in the tray and go to Options -> Properties -> Adjust volume for recording. Then you should be able to alter the volume of the line-in port.)
If it still doesn't work try to restart VirtualDub sometimes.
If you have a WinTV card try then to start the prog AudioSel.exe in the /wintv/ dir(or download it here), there you can choose TV Audio Source, if this doesnt work, you can restart virtualdub sometimes, or if you got the wintv/radio card, like I, you can choose radio audio source and this will work everytime /mrm
I've had the above problem and tried everything you said to get rid of it, but whatever i did nothing seemed to fix it..... until I went into control panel! I went into Control Panel, 'Multimedia'. Then under where it says 'Recording' I selected 'SB Live! Wave In (CC00)' instead of 'RSS Wave in Record' and the audio worked!!!
/Stuart
I have an ATI AIW 128 Pro and a Sound Blaster Live in an AMD 800 128 Mb RAM and I get no sound. When you choose video source on Virtualdub, you´l find the same settings of your capture device and soft. Despite this settings are correct, CLICK AGAIN on them and ¡voila!. The sound apears and everything works.I hope this can be usefull. Bye from Spain
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 22:57 -
how to use audio interleaving in virtualdub?
By sharmine in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2007, 03:00 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 22:51 -
VirtualDub + New Audio + Editing + Audio Intact?
By hech54 in forum EditingReplies: 6Last Post: 16th Aug 2007, 15:57 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
