I am in a situation where I am mounting a TV/Computer monitor on a track in a medical office. The track manufacturer ran VGA, S-Video, Composite Video and stereo audio down the pipe to the monitor. THey will not let me run coaxial. I need a device that will convert standard television signal to a s-video and stereo audio. I know that a cable box will work. I also understand that an inexpensive vcr will work. The only problem is that the location is very difficult to get cable to. Of course this is a ceiling mount and nowhere to put any cable box or vcr in the ceiling. I need any and all suggestions. Thanks so much for hte help.
What inputs are on the TV/Computer monitor? I'm assuming S-video anyway. What type of TV signal do you have for a source, RF or Line level such as composite? Broadcast TV or video signal from another source? If it's RF, then you need a tuner somewhere in the system.
And welcome to our forums.
What channels do you need to tune?Originally Posted by bhgewilson
Is a remote control going to work?
Here is a cheap solution. What more do you need?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=674680&CatId=1427
Here is a more deluxe model. What inputs does the TV/Computer monitor have?
http://www.aver.com/2005home/product/tvtuner/standalone/tvbox7/tvbox7_spec.shtml
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=108029&CatId=1427
Here is a more industrial strength model.
http://www.extron.com/download/files/brochure/avt100_ebro.pdf -
Yes this is what I was talking about. It would be very nice if we could find something without power but I forgot about changing channels. Sounds like a good idea. Thanks for helping.
If the monitor accepts composite/s-video then the easiest solution is to get a (cheap/used?) VCR and use the tuner of it.......
I am using this for years with the (PAL) monitors I have here around.......
Hauppauge 350 - Capture with Coaxial / S-Video / RCA ???
By samusaran in forum Capturing and VCRReplies: 17Last Post: 30th Jun 2010, 09:58 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Video Card with Coaxial Out
By cblythe303 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2008, 13:38 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
