Is there a software to compress recorded DVR shows to a 700MB CD, eg. the option of a nightly compression task which converts DVR to divx?
Google your DVR model number and find out how it stores the files and in what format. You should also be able to find advice on how to hook it up to your PC to be able to transfer stuff.
How to proceed after that really depends on how it stores the files.If in doubt, Google it.
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
DVR to DVD Software
By Chala in forum Capturing and VCRReplies: 17Last Post: 31st Mar 2010, 03:06 -
DVR to DVD Software
By Chala in forum Newbie / General discussionsReplies: 4Last Post: 14th Mar 2010, 14:19 -
Best BASIC DVR / PVR software that meets these criteria...
By madmartian in forum Capturing and VCRReplies: 15Last Post: 7th Jul 2009, 10:03 -
best gide and software to convert to Divx or xvid.
By Xcamera in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2008, 13:48
