Anyone know how to change windows' default telnet client (which is hyperterm). Actually, I would like to change how firefox reacts to ssh links, but changing the telnet client would be a good place to start.
Well, if I uninstall HyperTerm, what will be my default telnet app? Probably nothing. I can certainly try, but I don't think it would help.
You would obvoiusly need to install some other Telnet client in it's place.Originally Posted by mike909
If it's only File Extension based, then it's very easy to change what file extensions instantiate what programs. Go to Windows Explorer, and go to Tools > Folder Options > File Types, and change the associations for extensions which you want to use your alternative telnet client.If in doubt, Google it. -
That's exactly how you do it. The Telnet association is right near the top. Select the Telnet URI handler, click Advanced, then New. Enter as follows (assuming you're using Putty here):
Action: Run
Program used to perform action: c:\putty\putty.exe %1
Don't select DDE and click OK, then make it the default action by clicking the appropriate button.
change default aspect ratio without re-encoding?
By boonesmi in forum Video ConversionReplies: 14Last Post: 30th Aug 2012, 10:17 -
Pixelated videos - Is there a way to change the default renderer?
By klischee in forum Software PlayingReplies: 6Last Post: 29th Oct 2010, 17:21 -
Change default tracks in mkv (batch)
By Gabbsmo in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 08:58 -
How to change the IE 7 default setting of webpage Save As?
By coody in forum ComputerReplies: 0Last Post: 17th Aug 2009, 13:15 -
How to change default movie track?
By thomasbbb in forum MacReplies: 1Last Post: 6th Aug 2008, 14:36
