can anyone tell me whats the easiest and fastest way to remove those annoying subtitles from downloaded movies
If you mean those actually in the frame itself (i.e. hardsub), there isn't any except by trimming. What's behind it is gone and restoration will be a frame by frame operation, not worth the effort.
If they are not hard coded as kschang decribed, easy enough to delete, or just set your player to ignore them. And since this concerns subtitles, moving you to our Subtitle Forum where you might get more info.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
