Hi
I have to capture some old "Top Cops" episodes from VHS to DVD format for my brother.
I have no capture card, yet I know it is possible without one.
I do have: a video card,
VHS connected via composite cnxns,
my PC,
software(Virtualdub etc.)
Setting up in Virtuadub, I tried setting up my video source, but it shows no option except a blanked out 'no video source' on th pull down menu. ( 'Video-Video source-...no video source' )
Problem is I'm kinda clueless?? he-heh![]()
Any help? Thanks.![]()
Results 1 to 11 of 11
If you know it's possible, why can't you do it? Sorry, virtualdub is quite correct, you do not have a video source. The composite connection on your video card is to output video from your computer to a TV and not to input video.Originally Posted by Ben Boer
You will need either a capture card or external USB capture device. -
Ben Boer,
If you have video in, yes. Of course you still need to setup sound too. Don't want to miss the whirring of the police cars! Woooo woooo wooooo... Sorry
I didn't look yet, but are your pc specs and video card information up to date in your computer details? Most of us could tell you pretty quick if you're setup or not to do this.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I've just Googled for your video card and can't find any info about it. I found a Gigabyte one with the same number and using the same chipset and that has video out but no video in. Do you have the manual or a link to the card manufacturers website?
Oh dear, I believe I have been mistaken
I thought my card had video in- damn
NOw I'l have to buy one-..Hey Richard( or anyone else), what features do you recommend I look for in a capture card & is it ok to go low range?
thanks much appreciated!
e_v041(nx6600-td_series_lite).pdf -
Also...are results not better to use a seperate video capture card than your graphics card?
I agree with the DVD recorder suggestion. I'd also suggest finding out if the stuff you're trying to put on DVD is already released on DVD. Could save you a lot of work, not to mention net you results you'll never even begin to stack up to with a VHS transfer.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
For vhs to dvd recorder , you will need to investigate the vhs source for macrovision .
For most problem's a video stablizer will be required ... it can also help where vhs source has deteriorated ... these problem's cause havoc to recording device's .
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
Best S-VHS To best Capture card
By samturner01 in forum Authoring (DVD)Replies: 7Last Post: 15th Feb 2008, 19:00 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 8th Feb 2008, 00:27 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 09:00
so does it mean I cannot even if my v/card has video in?
