Hey thereSorry if this is the wrong forum, but I have tryed alot of things to get this removed and cant
Well I have tryed using spybot, ad-aware, norton, and it cant find the problem. I have use hijack this, and found a possible cause (it cant remove it):
O2 - BHO: (no name) - {6D794CB4-C7CD-4c6f-BFDC-9B77AFBDC02C} - C:\WINDOWS\system32\hggghif.dll
Google shows no information on this dll, and I tryed removing it in safemode and it wont work. When I reboot, I get the system 32 folder open up on startup.
I also have this item keep popping up:
Any ideas on what I can do?
Results 1 to 17 of 17
scan your computer here and see if it gives you a name of the problem
http://www.pandasoftware.com/products/activescan?NRMODE=Published&NRORIGINALURL=%2fact...ACHEHINT=Guest -
That may be a particularly nasty one. This site seems to have some good info:
http://forums.pcpitstop.com/index.php?showtopic=119368&pid=1211152&st=0&#entry1211152
They suggest a program called SmitfraudFix. http://siri.geekstogo.com/SmitfraudFix.php
Good luck, and let us know if you succeeded in removing it. (Or them.)
follow this: (XP, W2k only)
http://forums.tomcoyote.org/index.php?showtopic=61697 -
Ok I am back
I did use that fix reccomended, and it seems all to be gone! No longer is that annoying popup there, and it doesnt startup with the system32 folder opening. Although, my pc is now alot slower
It seems to have got rid of it, but slowed me right.
thanks alot guys -
Heres a log from hijack and then the fix:
Logfile of HijackThis v1.99.1
Scan saved at 19:07:11, on 15/06/2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Stardock\Object Desktop\WindowBlinds\wbload.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Apps\ActivBoard\nhksrv.exe
C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\ewido anti-malware\ewidoctrl.exe
C:\Program Files\Sony\Shared Plug-Ins\Media Manager\MSSQL$SONY_MEDIAMGR\Binn\sqlservr.exe
C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
C:\Program Files\Spyware Doctor\sdhelp.exe
C:\WINDOWS\system32\slserv.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\WINDOWS\system32\wdfmgr.exe
C:\WINDOWS\System32\alg.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Alcatel\SpeedTouch USB\Dragdiag.exe
C:\Apps\ActivBoard\MMKeybd.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIA BE.EXE
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\Program Files\Spyware Doctor\swdoctor.exe
C:\Apps\ActivBoard\TrayMon.exe
C:\Apps\ActivBoard\OSD.exe
C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
C:\Program Files\Mp3tag\Mp3tagQuickPick.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Documents and Settings\Joe\My Documents\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyServer = 209.19.202.160:8080
O2 - BHO: DAPHelper Class - {0000CC75-ACF3-4cac-A0A9-DD3868E06852} - C:\Program Files\DAP\DAPBHO.dll (file missing)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - C:\PROGRA~1\SPYWAR~1\tools\iesdsg.dll
O2 - BHO: Web assistant - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O2 - BHO: IeCatch2 Class - {A5366673-E8CA-11D3-9CD9-0090271D075B} - C:\PROGRA~1\FlashGet\Jccatch.dll
O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: DAP Bar - {62999427-33FC-4baf-9C9C-BCE6BD127F08} - C:\Program Files\DAP\DAPIEBar.dll
O3 - Toolbar: Web assistant - {0B53EAC3-8D69-4b9e-9B19-A37C9A5676A7} - C:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: FlashGet Bar - {E0E899AB-F487-11D5-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\fgiebar.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
O4 - HKLM\..\Run: [SpeedTouch USB Diagnostics] "C:\Program Files\Alcatel\SpeedTouch USB\Dragdiag.exe" /icon
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [ACTIVBOARD] C:\Apps\ActivBoard\MMKeybd.exe
O4 - HKLM\..\Run: [EPSON Stylus D88 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIA BE.EXE /P23 "EPSON Stylus D88 Series" /O5 "LPT1:" /M "Stylus D88"
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [Spyware Doctor] "C:\Program Files\Spyware Doctor\swdoctor.exe" /Q
O4 - Startup: Mp3tag Quick Pick.lnk = C:\Program Files\Mp3tag\Mp3tagQuickPick.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: Service Manager.lnk = C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
O8 - Extra context menu item: &Download with &DAP - C:\PROGRA~1\DAP\dapextie.htm
O8 - Extra context menu item: Download &all with DAP - C:\PROGRA~1\DAP\dapextie2.htm
O8 - Extra context menu item: Download All by FlashGet - C:\Program Files\FlashGet\jc_all.htm
O8 - Extra context menu item: Download Using &BitSpirit - C:\Program Files\BitSpirit\bsurl.htm
O8 - Extra context menu item: Download using FlashGet - C:\Program Files\FlashGet\jc_link.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Locate Spot on Map by GPS - C:\Program Files\Opanda\IExif 2.25\IExifMap.htm
O8 - Extra context menu item: View Exif/GPS/IPTC with IExif - C:\Program Files\Opanda\IExif 2.25\IExifCom.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_09\bin\npjpi142_09.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_09\bin\npjpi142_09.dll
O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll
O9 - Extra button: Run DAP - {669695BC-A811-4A9D-8CDF-BA8C795F261C} - C:\PROGRA~1\DAP\DAP.EXE
O9 - Extra button: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\flashget.exe
O9 - Extra 'Tools' menuitem: &FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\flashget.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {14B87622-7E19-4EA8-93B3-97215F77A6BC} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab31267.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1128859731046
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - http://messenger.zone.msn.com/binary/ZIntro.cab32846.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{90101BDF-FECF-4181-8ADF-B9E6C584BCAA}: NameServer = 62.241.162.200 62.241.163.201
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O20 - Winlogon Notify: hggghif - C:\WINDOWS\SYSTEM32\hggghif.dll
O20 - Winlogon Notify: WB - C:\PROGRA~1\Stardock\OBJECT~1\WINDOW~1\fastload.dl l
O20 - Winlogon Notify: winzzd32 - winzzd32.dll (file missing)
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido anti-malware\ewidoctrl.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: Norton AntiVirus Auto Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
O23 - Service: Netropa NHK Server (nhksrv) - Unknown owner - C:\Apps\ActivBoard\nhksrv.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Panda Process Protection Service (PavPrSrv) - Unknown owner - C:\Program Files\Common Files\Panda Software\PavShld\pavprsrv.exe (file missing)
O23 - Service: Remote Packet Capture Protocol v.0 (experimental) (rpcapd) - Unknown owner - %ProgramFiles%\WinPcap\rpcapd.exe" -d -f "%ProgramFiles%\WinPcap\rpcapd.ini (file missing)
O23 - Service: SAVScan - Symantec Corporation - C:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
O23 - Service: ScriptBlocking Service (SBService) - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
O23 - Service: PC Tools Spyware Doctor (SDhelper) - PC Tools Research Pty Ltd - C:\Program Files\Spyware Doctor\sdhelp.exe
O23 - Service: SmartLinkService (SLService) - Smart Link - C:\WINDOWS\SYSTEM32\slserv.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
SmitFraudFix v2.60
Scan done at 18:15:41.48, 15/06/2006
Run from C:\Documents and Settings\Joe\My Documents\SmitfraudFix\SmitfraudFix
OS: Microsoft Windows XP [Version 5.1.2600] - Windows_NT
Fix ran in safe mode
»»»»»»»»»»»»»»»»»»»»»»»» Before SmitFraudFix
!!!Attention, following keys are not inevitably infected!!!
SrchSTS.exe by S!Ri
Search SharedTaskScheduler's .dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\SharedTaskScheduler]
"{9ae613a2-a13b-4379-8d0e-86a1a78476ec}"="corindon"
[HKEY_CLASSES_ROOT\CLSID\{9ae613a2-a13b-4379-8d0e-86a1a78476ec}\InProcServer32]
@="C:\WINDOWS\system32\rmzdzx.dll"
[HKEY_CURRENT_USER\Software\Classes\CLSID\{9ae613a2-a13b-4379-8d0e-86a1a78476ec}\InProcServer32]
»»»»»»»»»»»»»»»»»»»»»»»» Killing process
»»»»»»»»»»»»»»»»»»»»»»»» Deleting infected files
C:\WINDOWS\system32\hp???.tmp Deleted
C:\WINDOWS\system32\ld????.tmp Deleted
C:\WINDOWS\system32\ot.ico Deleted
C:\WINDOWS\system32\regperf.exe Deleted
C:\WINDOWS\system32\simpole.tlb Deleted
C:\WINDOWS\system32\stdole3.tlb Deleted
C:\DOCUME~1\ALLUSE~1\Desktop\Online Security Guide.url Deleted
C:\DOCUME~1\Joe\FAVORI~1\Antivirus Test Online.url Deleted
C:\Program Files\MalwareWipe\ Deleted
C:\Program Files\SpywareQuake.com\ Deleted
»»»»»»»»»»»»»»»»»»»»»»»» Generic Renos Fix
GenericRenosFix by S!Ri
C:\WINDOWS\system32\rmzdzx.dll -> Missing File
»»»»»»»»»»»»»»»»»»»»»»»» Deleting Temp Files
»»»»»»»»»»»»»»»»»»»»»»»» Registry Cleaning
Registry Cleaning done.
»»»»»»»»»»»»»»»»»»»»»»»» After SmitFraudFix
SrchSTS.exe by S!Ri
»»»»»»»»»»»»»»»»»»»»»»»» End -
Having Multiple anti-spyware and anti-virus programs all running at the same time will cause some performance issues. Also note the root of the problem seems to be the installation of a "fake" anti-spyware program, which was itself actually spyware.
Glad you got it off your PC,here's another good online virus remover:
http://safety.live.com/site/en-US/default.htm
(use Protection Scan)
BTW...make sure you disable System Restore before running any anti-virus software.
Here are a few tips to make your online experience safe and secure:
1.Use a firewall,Zone Alarm is one of the best free firewalls.
2.Disable Remote Assistance,it's unlikely you will ever use this feature.(WinXP)
3.Disable Windows Messenger,go to Control Panel->ADD/Remove Programs->Windows Components.If you have Office installed also go to Tools->Options and disable.
If you use IE you can also disable it in Tools->Manage Add-ons.
4.If you use IE go to Internet Options->General and set History to 0, then go to Privacy tab->Advanced and select Override Auto Cookie Handling->Select Block all third party cookies and allow session cookies.Now go to the Advanced tab and disable Auto Inline Complete and disable Profile Assistant,enable "Empty Temporary Internet Files...".Now go to the Content tab->
AutoComplete and untick all except Web Addresses,then Clear Forms and Clear Passwords.
5.Use Windows Update weekly.
6.Use an anti-spyware program such as Lavasoft Ad-Aware or Spybot weekly.
7.Install anti-virus software or use an online virus remover tool such as Panda or Microsoft Live.
8.When you're not using the internet disable your modem or disconnect the line,hackers can't get in.
9.Keep financial/confidential information on a disc rather than your hard drive.
10.Before buying online go to www.resellerratings.com or www.bbb.com to check the store.
11.DO NOT DOWNLOAD FREE SCREENSAVERS,they are all trojan/spyware laden. -
Ok seems I have this trojan:
http://de.trendmicro-europe.com/consumer/vinfo/encyclopedia.php?LYstr=VMAINDATA&vNav=3...TROJ_CONHOOK.H
I have been unable to remove this in safe mode, or by any method (must be the one)
will have to look around on how to delete it. -
Here's a site (by Emsi Software, better known for A-Squared) specific to scanning for/removing trojans:
http://www.windowsecurity.com/trojanscan/
Worked for me once on a nasty one. Good luck.Pull! Bang! Darn! -
Just did one of these today at work....
If you can hook up your windows drive to another computer and scan the boot drive with something like Norton 2006 to clean it. Follow up with Webroot's Spy Sweeper. Spybot S & D, Ewido.
At the end the machine was clean but IE was slow loading. SO I uninstalled IE6 and rebooted, Re-installed IE6 and Blammo back to proper speed.
Good Luck -
a little dated, but still useful.
http://forums.anandtech.com/messageview.aspx?catid=33&threadid=1658987&enterthread=y -
I have managed to remove the trojan it seems with windows recovery console. Although my pc is going as slow as hell, startup takes about a minute and also programs are very slow to load up
I also keep getting explorer, photo viewers, internet explorer etc freezing up and having to close them or reboot. Is there anything I can do to solve this? I have ran multiple scanners and found no problems
Thanks! -
After your sure you've removed the malware, you may want to
set a new restore point as well.
Just be sure not to revert back to a date past your newly created restore point, as you may reactive the malware.
Sabrowww.sabronet.com - It's all you need...to know -
Originally Posted by John_Jordan
Start -> Run -> sfc /scannow
Note the space after sfc. Takes less than half an hour on my machine. It won't tell you anything, i.e. whether any files were bad, but it won't hurt anything. Good luck.Pull! Bang! Darn! -
I think that this is just another "urgent message" you get from the net. To prevent them from getting to you, go to CONTROL PANEL > ADMINISTRATIVE TOOLS > SERVICES, double-click on MESSENGER, select STOP, then in the STARTUP TYPE window, select DISABLE. You will never get this type of "message" again.
Most systems can do quite well without the MESSANGER service (even those networked).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
problem with MPC/HC after spyware removal
By spiritgumm in forum Software PlayingReplies: 4Last Post: 6th Mar 2011, 09:55 -
What do you do to keep your PC safe from Virus spyware
By spiderman2k1 in forum ComputerReplies: 48Last Post: 6th Nov 2010, 00:44 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 21:28 -
Problem removing spyware/virus
By Squid_uk in forum ComputerReplies: 8Last Post: 8th Oct 2007, 10:33 -
Trickly little virus/spyware.
By dimtim in forum ComputerReplies: 17Last Post: 23rd Jun 2007, 13:04
