    May 2006
    I am wondering if the disk that I burned with Disk Utility is region free or did it automatically burn in the region that my Matshita DVD drive plays. Here is what I did: I recorded video from my VHS player directly to a cyberhome DVD recorder. Then I put the DVD in my mini and saved the Video_TS file to my external drive. Then I combined an img made with iDVD with the Video_TS file I just saved, sent it through ffmpegx and created a new img. Then I burned to DVD with disk utility. Is the DVD region 1 or region free? I assume region 1 but clarification would be great. If it is region 1, what would be the easiest way to burn a region free disk and what software should I use? I have a variety of programs installed on my computer that I have never used such as: mac the ripper, mpeg streamclip etc. and I don't have Toast or Popcorn.
    Jan 2006
    Dec 2003
    Eugene, Oregon
    Disk Utility has no ability to add region codes to discs. It is region free. Note also that Disk Utility will not format a DVD in UDF format required for video DVD, so if you had tried to burn a VIDEO_TS folder with Disk Utility it wouldn't play in a DVD Player. You apparently know that which is why you had ffmpegx create a disc image file instead. There is a freeware application called DVD Imager which also creates UDF-formatted disc image files for burning with Disk Utility.
    Since you have a standalone recorder you might consider getting Toast 7. It can extract MPEGs from video-mode and VR-mode DVDs created by standalone recorders and then re-author (along with other content) to new DVDs. I do this all the time now with VR-mode DVD-R's recorded on my Pioneer standalone recorder.
    May 2006
    Thanks a lot for the info!
