How do you make FlasKMPEG to recognize the Cinemacraft Encoder Plug-in? After I installed both of them I could not see it under the "output options" menu. Please help.
Install the cce plugin (default target dir is c:\adobe\premiere\plugins\ or similar). Then copy the plugin to the flask dir and rename it from *.prm to *cm.flask
Truman
Do you have to have Premiere to use CCE and Flask??
I have CCE and Flask whats the instructions to get Flask to recognise CCE?
T 3 X -
If you want install CCE plug-in in FlaskMpeg but you don't have Premier, you can't install the plug-in.
Go to http://www.doom9.net download a program "Adobe Premiere Plugin regfix" you are able to install CCE plug-in into FlaskMpeg, then rename file "cm-mpeg-cce.prm" to
"cm-mpeg-cce.cm.flask" in FlaskMpeg folder. That all you have to do.
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Is there a software or plugin?
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2011, 20:43 -
Cinemacraft Encoder..Black void after encode
By Soixante in forum Video ConversionReplies: 6Last Post: 28th May 2008, 03:43 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
how to make ffmpeg recognize an uncompressed quicktime source file?
By eighth in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:09
