Virtual Dub not letting me convert to Panasonic DV .avi
it says "The source image format is not acceptable (error code -2)"
any ideas?
I only used Panasonic DV only for decoding. I never used it
for encoding. And I do not know if it can be used for encoding.
For encoding, I always use PicVideo codec. Check your system
if it is there. I have Pinnacle Studio 9 and it includes PicVideo
codec. -
The Panasonic DV codec can be used for decoding and encoding. But DV has a fixed format. If your video does not meet that format, you will get that error when decoding or encoding. If you are compliant, then you have another problem.
Yes, just tried it and it can be used for encoding.
Never used it before.
Actually, my input video is 1080i mpg from HDTV.
I down size it to 720x480i at 29.97fps. You can
try the following using virtualdub to see if it
works or not.
video->filter->resize->720x480i
video->frame rate->29.97fps
video->compression->Panasonic DV
file->save avi -
The panasonic DV codec can sometimes hijack other codecs, such as Div3, and try to playback material that has the wrong resolution. I have used the FFDShow VFW codecs to steal playback from the Panasonic codec as required.
Read my blog here.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 18:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
I have suddenly lost the ability to convert to DiVX with Virtual dub
By DaneClark in forum Video ConversionReplies: 6Last Post: 8th Jul 2009, 08:16 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
