Hi Im new to this forum so if this is already up im sorry. Anyways
The Problem = im trying to convert my MKV. files to AVI. files using
MKVtoolnix - MKVextract GUI - to extract everything
DbpowerAMP Music converter - to convert the aac audio file to MP3
VirtualDubMod - To put it all back together
My problem is with any anime MKV. with the first audio as Japanese and the second as English
(i have sucsesfully converted 14 MKV's of the same series with English as the first language and Japanese as the second)
The audio and video is out of sync and the completed AVI file has a running time of 19.54 instead of 24.11 but the video is all there
The video is only 19mins 54seconds but the audio is fine at 24mins 11seconds WHY
I have tried reinstaling all of the programs as i thought it might of been an error ive tried converting with change frame rate so video and audio durations match but to no avail
PLEASE HELP IM TEARING MY HAIR OUT (and i need my hair)![]()
mkv supports VFR. When you assume that something is CFR (as happens if you extract to avi) when it is infact VFR, the length changes.
Try to extract the mkv (video only) with the latest version of virtualdubmod. You can try to extract the audio too but VDM doesn't support all audio. And the audio may come out weird and will not work. So better use MKVextract GUI instead.
Extract the rest of the mkv with MKVtoolnix - MKVextract GUI.
If you can't open the mkv in virtualdubmod modify the mkv file with one of those mkv tools. Delete all subs, other files and maybe the audio too so you left with the video file only. You should be able to open it now.
It took me awhile to come up with this method, but it should work. I haven't done any mkv reencoding for some time so maybe there's a shorter way, because doing my way takes loads of time.
I had that problem too.. all those frustration
I have uses MKVmerge GUI to make a file with just the Video then extracted the Audio and Subs with MKVextract GUI, converted the audio to MP3 using dBpower AMP then put it all back together with Virtual Dub Mod
WORKS A TREAT 8)
IM SO HAPPY THANK YOU SO MUCH
Audio out of sync when converting from MKV
By carlmart in forum Video ConversionReplies: 8Last Post: 22nd Dec 2012, 17:07 -
mkv conversion to dvd sync error
By wolfdogg in forum Video ConversionReplies: 8Last Post: 8th Feb 2012, 11:02 -
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:56 -
Error in Virtualdub while converting mkv to avi
By anchonio in forum Video ConversionReplies: 6Last Post: 1st Aug 2011, 03:36 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10
