  1. I read the sticky on editing DVDs made on a standalone unit and couldn't find an answer
    I have a JVC MH30 DVD recorder and want to add a menu with chapters and titles to a DVD made on it without re-encoding it. Can someone tell me if I can do this with one of the tmpg products, and if so which would be the easiest to learn.
    Thanks so much
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Without re-encoding: Yes. Without re-authoring: No. TMPGEnc DVD Author should allow you to import your title(s) and then you can configure menus to taste.
    If in doubt, Google it.
