I've been using mencoder and ffmpegX to make NTSC spec MPEG-2 files to burn off to a DVD. I was surprised to learn that Quicktime cannot open or play these files without an additional plug-in. So it should come as no surprise that iDVD will always re-encode your files for DVD regardless of their source format.
What products are available that will let me create simple DVDs and accept pre-formatted and encoded video - WITHOUT re-encoding (only VOB creation and burning...) ?
ffmpegX has a nice "author as DVD" option for single files, but I'd like to do something a little nicer. Not too fancy - anything of the same level as iDVD would suffice.
I should also mention that I've been attempting to re-encode my video with something that Quicktime _can_ read so that I can use iDVD. I figured if I scaled and encoded it with a high quality process at a high bit rate I might be able to live with the extra encoding step. However, I can't seem to encode with a codec that Quicktime can read. Using mpeg4 in mencoder doesn't work, and neither does h263+. This is all complicated by the fact that my files are in the Real Media format, and ffmpegX (which will write a playable MPEG-4 .MOV file) cannot decode them - only mencoder with the latest RealVideo codecs is able to do so.
It's never as simple as it seems....![]()
Toast sounds perfect, but I've been having difficulties verifying that it will let me create the VOBs and title sets from already properly formatted MPEG-2 files - without re-encoding them. You're sure?Originally Posted by rumplestiltskin
Yes; you may select "Never" in the "Reencode" popup menu when you select "Custom" encoding. This will work as long as your MPEG2 files are properly encoded in the first place.
Sweet! Thank you for taking time to reply.Originally Posted by rumplestiltskin
we just released an app that is perfect for your goal. hawkeye 1.0 released
Combine Mpeg-2 Files (without re-encoding or loss of quality)
By Anonymous642 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2011, 07:58 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 02:18 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 09:09 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 04:23
