hi guys.
im trying to establish the best format to use with svcd2dvd?.
if i rip a dvd
1.whats the best program to use?
2.what format do i convert it to for best quality/ease of use with svcd2dvd?.
i.e xvid/divx/kvcd/mpeg1/mpeg2 etc etc.
for example i want to put a trilogy set onto 1 dvd5 disk.
so i am looking to rip the dvd into a format that is excellent quality,but easy to use.
thank you in advance for any help or advise.![]()
The best ripper has always been DVD Decrypter but newer DVD's will require something more up to date. Try DVDFab Decrypter or AnyDVD for ripping.
Ideally, once it's ripped, I would recommend DVD2SVCD with CCE to get a good quality file in DVD format with the proper output size, then use SVCD2DVD to author. That being said, CCE is prohibitively expensive.
If not using DVD2SVCD, I would try an XVID conversion (do a guide search), then run through SVCD2DVD to convert and author.
3 movies on a DVD5 will be a tight squeeze as far as quality. If you have a dual layer burner, I would put the trilogy on a DVD9 with SVCD2DVD.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
