I recieved SuSe 9.1 Pro in the mail and would like to install the xvid codec in it. How would I do this?
This is a block of text that can be added to posts you make. There is a 255 character limit
Most SuSE users use the Pacmkan web site to get rpms. For example:Originally Posted by StealthKing
xvid - http://packman.links2linux.org/index.php4?action=172&vn=14
xvid4conf - http://packman.links2linux.org/index.php4?action=408&vn=13
There are MANY other compiled rpms (codecs, players, encoders, etc .... ) for SuSE, on the Packman site. I recommend you explore the site and determine what is available. -
I used the rpm things. I can only install it from konqurer though. Somethings wrong with YAST in the OS. Anyone know how to fix it? WHat are some good books on programming in Unix? Do they use C or C++? I want to learn to make my own apps.
installing codec locally...
By proxima centauri in forum ProgrammingReplies: 2Last Post: 21st Apr 2010, 09:17 -
How do I use the Xvid codec without really installing it?
By KneeRow in forum Software PlayingReplies: 1Last Post: 18th Apr 2010, 16:27 -
Installing the H.264 codec for use with TV tuner
By MrJacky in forum Capturing and VCRReplies: 30Last Post: 23rd Sep 2009, 08:08 -
Installing H.264 Codec Encoder
By hzgg2 in forum EditingReplies: 2Last Post: 20th Jul 2008, 15:47 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 09:56
