Im converting mp3s over to wav for my cds and is trying to change the volume of songs to the same level and clean them up also. Do i need to do this in the mp3 form or go ahead and convert it to wav file and do it?????
Results 1 to 16 of 16
I convert them to mp3's and then edit the MP3's when needed. Good Luck....
If you're starting with MP3 then it's a fair bet that some of the quality has already been lost forever - it's a generic thing with highly compressive formats. Far better to start off with WAV files if possible.
If that's not the case, then I don't see any reason why you couldn't open the MP3 files directly, do your volume enhancements and cleanup and then export as WAV files. They key when working with compressed material (be it video or audio) is to limit the number of recompressions, as each re-compression will affect quality.If in doubt, Google it. -
have a look at my post please
https://forum.videohelp.com/viewtopic.php?t=302756 -
dell6806, your post is not related to this thread. This is considered 'Threadjacking' and a violation of our rules.
Please read our rules before posting: https://forum.videohelp.com/viewtopic.php?t=124514Do not hijack topics.
Please try to stick to the author's first post in each topic, if you want to discuss something else, create a new topic.
If you have a unrelated question, start your own thread. If your present thread has not been answered, please be patient. Someone will likely reply.
Thanks, Moderator redwudz -
MP3Gain will 'normalize' the audio levels of your MP3s without re-encoding them. It will do batches of them to normalize either individual songs (loudest part of that song moves up or down to 0 dB) or albums (loudest part of the whole group moves up or down to 0 dB).
Originally Posted by olyteddy
ok... well what i did was change the normal volume to 99 while all the songs was selected but there is no way to apply it to all the songs... i see where i can apply gains but no volume. -
As the man says the "normalise" function will "average Out " the volume for you automatically. If you are writing MP3's to CD I believe the likes of Nero has a normalise feature and will also do the converting to CD's for you all in a oney. There are other programs which do similar i believe. I have used Nero in the past and it has worked perfectly fine.Originally Posted by olyteddy
Hope this helps...good luck -
what im asking is how do i normalize all the songs to the same volume with mp3 gain ????
Then use 'Track Analysis' and 'Track Gain' settings. That will do each track by itself.
you can directly convert mp3 files to wav files. But regarding , changing the volume we have to do it only in the wav file form. To give you an information, whatever the conversion may be (wav to mp3 or mp3 to wav ) there is sure in quality loss. For doing this
i used SPAMMER and if you wish just try using this. -
ok i used it and burned it to cd and most of the songs sounds close but i can tell some of them the volume is still off.... then i tried another batch of songs and come to find out that the program didnt put all of them at the same volume.... some came close but no cigar.... for example.... if i set the volume for 96 and did apply album gain... some came to 92, some to 97 and some to 90.... a lot of them didnt do the 96 i set.... so did i do something wrong or is it the software?????
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
InFanView How do I edit size and get it to print the edit
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2008, 10:51 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
