Maybe someone can help me with a problem I have been having recently. I was trying to burn some fansubs I have on DVD like I have done in the past and to my knowledge the process goes smoothly as always; I receive no errors.
However when I try to play the new DVD on my DVD player it is unreadable, I run into the same problem on my two other PC DVD players as well. I tried re-burning twice only to get the same results. I am using Fujifilm DVDs but in the past I have used Sony and TDK, maybe that is the reason?
Could be - with the disk in the same drive that you appeared to have successfully burned it in, go to nero smartstart - extras - disk info - what info does it say about the disk. After burning it will it play in the drive that you burnt it with ?
Recovered data unplayable
By RonnyKedia in forum Software PlayingReplies: 6Last Post: 3rd Feb 2012, 14:59 -
Unplayable recovered .mov files
By UndeadInfection in forum RestorationReplies: 2Last Post: 27th Feb 2011, 15:35 -
Unplayable DVD - except on one player (?)
By tloewenberg in forum Newbie / General discussionsReplies: 11Last Post: 10th Mar 2009, 22:36 -
Backing up ORIGINAL dvds renders them unplayable? HELP!
By emanpunk in forum DVD RippingReplies: 31Last Post: 2nd Mar 2009, 19:37 -
Unplayable dvds made on Sanyo DRW-500
By ronl44 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Dec 2007, 13:25
