  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I have a harddrive that has a recovery partition and and OS partition on that same drive. is there anyway to just delete the recovery partition? Or would I have to do format on just that partition or both or just the main drive itself that the partition is on? I'm a liitle lost? What I want to have is my 200GB as one drive instead of the the 192GB, and then the 8GB partition......
    What We Do In Life, Echoes In Eternity....
  2. Banned
    Feb 2005
    USA
    delete both partitions. setup a single partition and format it. install the os.
    May 2005
    Toronto ||*||
    Hi,
    Best freeware solution would be a linux based live CD.
    I recommend you try out PCLinuxOS. It has a partition editor so you can delete/resize partitions. If you're not familar with Linux don't worry it has a GUI.
    To give you a heads up, if you go this route burn the CD @ max 2x.
    Whoa to open source.
    Hope this helps.
