Is it possible that when i render a mpg in Vegas that the video looks "soft"
the video footage is coming out very soft compared to the original video
You may have two issues:
1) Vegas may be showing a deinterlaced image which will look a little less sharp but will be free of interlace comb artifacts.
2) TVs normally receive a fuzzy picture and have sharpening filters to make it look more crisp. Computer monitors normally receive a very sharp picture from the graphics card so they do no sharpening. So when you look at video on a computer it usually appears less sharp than when viewed on TV -- even if the two displays are the same size, and even though the computer monitor is capable of a much sharper picture.
Another thing to consider: computer monitors have very different gamma curves than TVs. Unless the program displaying the video on the computer is correcting for this you will see a darker and more saturated image on the computer. -
Well, that's not normal. There should be very little drop in sharpness when converting to MPEG. For example going from 720x480 DV AVI to 720x480 MPEG should look nearly identical in terms of sharpness.Originally Posted by snapware
What is the frame size of the AVI source? What video codec is it?
What is the frame size of the resulting MPEG file? What video bitrate are you using?
Are you deinterlacing? -
So Far so good.... this man is a genious.Originally Posted by LloydAZ
Converting several flv videos into a single DVD video with ConvertXtoDVD4
By Codonauta in forum Video ConversionReplies: 2Last Post: 17th Feb 2010, 20:31 -
Logo Stripping From MPG2 Videos?
By mediachimp in forum EditingReplies: 7Last Post: 2nd Feb 2010, 17:37 -
Converting videos copied to a DVD
By VSE in forum EditingReplies: 10Last Post: 20th May 2008, 19:55 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 10:36 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 05:59
