I have managed to capture an avi file of a streak of lightening hitting the ground, and I am wondering if I can extract this frame to a jpeg or other image file.
Does anyone know of a method of doing this.
Thanks in advance
Just about every video editing package can save frames as image files. Try VirtualDUbMod.
Many media players have the ability too although it may be harder to get exactly the frame you want. Try Media Player Classic. -
You didn't mention the source but I'll assume it is a camcorder and the AVI is interlaced video. For a lightening strike there will be considerable motion between field one and field two for the frame.
This is a case where field capture may be more appropriate than frame capture.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
See the second sticky from the top in this forum.
/Mats
By Toastie in forum ComputerReplies: 2Last Post: 19th Aug 2013, 01:00 -
Single Jpeg to mpeg2.
By dylz in forum Video ConversionReplies: 2Last Post: 11th Feb 2011, 12:43 -
extracting jpeg frame by frame from video
By goofymickey in forum ProgrammingReplies: 0Last Post: 16th Dec 2010, 08:02 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Saving a single Frame as a Jpeg
By acestu in forum EditingReplies: 0Last Post: 20th Aug 2008, 16:11
