Hi,
A friend gave me a hard drive.
I'm looking to connect it to my computer via IDE connection if possible. The specs
of the drive are here:
http://www.span.com/catalog/product_info.php?cPath=23_504&products_id=4956&print=1&osC...b1cb3b2bc1ca6d
Can someone recommend the type of cable to use for this type of HDD to enable connection to IDE??
Thanks!
Results 1 to 9 of 9
Just looked for an adapter but couldn't find one. Why, though, would you want to degrade your computer's performance with such a slow drive? It's meant for handhelds.
ZIF just means Zero Insertion Force. It doesn't tell you anything about the adapter socket or plug. Most all computers use a ZIF sockets for the CPU. (The one with the little arm.) You would have to go to Hitachi's website and look for one of their spec sheets on the drive to find out how many pins, size, and hopefully a standard part number.
Aren't all these ZIFs a standard 40pins using a standard 22mm cabling? I do not know of any adapters made for them either.
Thanks for the input guys. Basially this HDD belonged to a JVC EVerio unit that unfortunately suffered some physical damage and I'm looking to salvage some valuable footage.
I was going to do the same thing with a similiar drive. I was told their was a USB adapter for it but I could never find one. If you do can you let me know. I still have the drive.
Steve's Digicams has a article on IBM/Hitachi Microdrives. Might be some info there. Most of them are inside a small case, though, not bare drives: http://www.steves-digicams.com/microdrive.html There is also a link there to Hitachi where you might find a spec sheet if you have the model # of the drive.
ZIF to 3.5" IDE Adapter
http://store.era-ele.com/ziflif-ce-18-hdd-to-ata-35-ide-hdd-adapter-p-46.html
ZIF to 2.5" IDE Adapter
http://store.era-ele.com/ziflif-ce-18-hdd-to-ata-25-ide-hdd-adapter-p-45.html
ZIF to SATA Adapter
http://store.era-ele.com/ziflif-ce-18-hdd-to-serialata-sata-hdd-adapter-p-251.html
Many Other ZIF CE Adapter
http://store.era-ele.com/computer-adapters-zifce-hdd-adapter-c-12_13.html
SATA to IDE adapter.
By Poppa_Meth in forum ComputerReplies: 31Last Post: 6th Jan 2014, 15:47 -
YPrPb adapter
By BlackBumblebeezzz in forum Newbie / General discussionsReplies: 24Last Post: 19th Sep 2010, 14:11 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 22:40 -
IDE to Sata adapter....
By kenmo in forum ComputerReplies: 4Last Post: 2nd Apr 2008, 13:11 -
About IDE to USB adapter cable
By AusTaylor in forum ComputerReplies: 7Last Post: 4th Feb 2008, 00:18
