I have a video I have shot and edited. It is currently 1.2gig in AVI format. I am wanting to post the video online, but the max filesize limit is 100meg. Can anyone give me advice on how to get this video down to under 100meg without loosing too much of the quality? Thanks.
Results 1 to 9 of 9
How long (in time) is it?
/Mats -
Well, you most likely want to save that DV-AVI file to archive once edited (DVD-R, and/or back to TAPE). But you also want to go with something that is viewable on the web, in reasonable sizes. DV ain't!
So you're gonna have to export/recompress to MPEG1, or WMV9, or MP4 or similar (DivX/Xvid).
Your program is only ~5 2/3 minutes long (~350sec), so you have plenty to work with: 100MB = 800Mbits /350sec = 2.28Mbps, which is very good DVD quality for all the above except MPEG1. You would use MPEG1 only for universality, not quality (it's too old of a codec to be very efficient). So, I'd say drop the bitrate to ~750kbps, which gives you ~32MB file of still quite good quality.
Scott -
Also one suggestion is if you stick with divx to convert the audio to mp3. That is uncompressed pcm audio there which will really increase the file size more than you need.
I do recommend windows movie maker to output to wmv. It can do a really good job of shrinking files and making them decent. Though to get to a 100megs you'll probably have to use a much lower video resolution to make it work.
Good luck.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks Scott,
EDIT: Nevermind, I just imported the AVI into Adobe Premiere and re-encoded it at 320x240 with MPEG-1 and MP3 audio and got the whole thing down to 85meg. -
Glad you're happy, but that won't look as good as what I was suggesting.
Scott -
Even if that's fine, it's a very odd combination. Your average mpg1 comes with MP2 audio.Originally Posted by LordPython
/Mats
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 14:31 -
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 11:10 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 08:29 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36 -
Making file smaller in Adobe Premiere Pro
By JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 15:07
