  1. Hello I need help puting a couple of .OGM files on a dvd but the ogm file has like 2 audios u can chose from like japanese and english and I want both to be on it so I can choose which audio I want with my remote oh and the file also has subtitles and I also want to include that in there. The problem is sonic(my burner) doesn't support that format.
    USA
    You could use VirtualDub Mod and this guide: https://www.videohelp.com/forum/viewtopic.php?t=222005
    You might be able to do this with ConvertXToDVD, though I don't know if it will accept OGM video. But you could save out the audio as WAVs using VDMod and it will take those. The video may be Xvid, you would have to check.
