I have a training file that I downloaded from the Internet that I want to edit as it is incomplete. It is a .exe file that opens up with Macromedia Flash. Is there any way I can edit this without spending a bundle on software? Thanks...
Results 1 to 9 of 9
zip is hip
A hex editor can edit any kind of file. Will it work after your edits? Only if you have a really deep understanding of the exe you're doing brain surgery to.
/Mats -
My thought too, but as this .exe "opens up with Macromedia Flash" it may be video related.
/Mats -
good point. it is video as it does open with Flash. I was hoping to find a video editor so that I could cut out some areas of the video. any ideas?
zip is hip -
it is a presentation with 48 frames and audio. I simply need to delete the 48th frame of this presentation which runs by itself just like a avi file would. ugh, no good at brain surgery so that hex editor won't help me. what do you think?
zip is hip -
Don't know if there are any free Flash editors (doubt it) but maybe it can be converted into something editable?
Worst case - Play it, and "screen capture" it to AVI.
/Mats
Question about how to modify exe file
By jimdagys in forum ComputerReplies: 9Last Post: 29th Oct 2011, 18:59 -
ffmpeg.exe - Target file size?
By Gew in forum Video ConversionReplies: 0Last Post: 25th Feb 2009, 14:46 -
EXE file to video format?
By rdfarr in forum Video ConversionReplies: 3Last Post: 16th Dec 2007, 18:47 -
EXE video file
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 15:57 -
has anyone got the old 2.1 .exe file
By NIPPERLOCKO in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 27th Oct 2007, 13:35
